Give Rating in ID3v2.3 header higher priority over Rating in Music Library?
Topic: Give Rating in ID3v2.3 header higher priority over Rating in Music Library? (Read 2639 times)
October 25, 2020, 11:08:36 »
thoste
Assume I have a playlist with a aaaa.mp3 song.
The Rating in AIMP playlist for this aaa.amp3 songs shows 5 stars and ID3v2.3 header contains an equivalent rating value of 5 stars (check with Mp3tag tool).
Now I changed the physical file name of this aaaa.mp3 file to bbbb.mp3 and dragged it again to the same playlist.
Much to my surprise the new entry shows only 2 stars!
Why?
I guess its because the music library contains some odd values of only 2 stars.
How can I tell AIMP to ALWAYS give the Rating value in ID3v2.3 header a higher priority over Music Library data?
AIMP should forget/ignore all Ratings in its Music Library.
If the ID3v2.3 header does not contain a Rating value or even has no ID3 header then 0 stars should be shown in playlists.
Thomas
Last Edit: October 25, 2020, 11:45:48 by thoste
Re: Give Rating in ID3v2.3 header higher priority over Rating in Music Library?
October 25, 2020, 11:59:36 »
Карма: +3215/-78
Just setup music library synhronization with file tags
October 27, 2020, 16:47:25 »
thoste
I think enabling enabling this option only means
"store NEW Rating into Music Library"
But what about the existing ratings? They are not updated in Music Library.
How can I force AIMP to write the currently visible Rating stars (derived (possibly) from ID3v2 tag) even for already existing songs into Music Library?
October 27, 2020, 19:53:04 »
Карма: +3215/-78
AIMP always store rating in music library, so rating imports from file tags on file adding only
