Music plays high speed after a pause
Topic: Music plays high speed after a pause (Read 3070 times)
October 15, 2020, 01:48:04 »
Drdan
Hello,
Hope someone can help.
I use an Nvidia at android 9.0 with aimp at 3.01 with the latest build.
Problem is repeatable.
When I leave aimp it properly loses focus for some different audio. On losing audio focus it pauses the song as desired.
After several minutes (maybe 20) I return to aimp to listen to more music. The problem now happens.
Aimp plays every selection at very high speed. It takes less than 10 seconds to play a complete 4 minute song. There is no sound at all. I am judging the song time by watching the sound progress bar. It then advances to the next song and remains at high speed.
I have tried everything I can think of to make it stop. The only way I can make it play at the correct speed again is to go into the android settings, select apps, select aimp select "force stop". Then return to aimp and restart it. It now plays properly again.
Sire hope there is a cure. I really love this player.
Best regards,
Dr Dan
