Autotagging error GDI+ (Code 2)
Topic: Autotagging error GDI+ (Code 2) (Read 4140 times)
September 22, 2020, 05:55:40 »
Southernwave
I have suddenly started to get a lot of GDI+ (Code 2) errors when using the Autotag option in the TAG EDITOR.
It locks the editor completely and I have to crash out ..... usually when I try to edit the same file a second time it works.
Any thoughts ?
A
Re: Autotagging error GDI+ (Code 2)
September 22, 2020, 06:11:20 »
Карма: +3241/-85
What is your version of player?
September 22, 2020, 22:52:43 »
Southernwave
V4.70 build 2227 on latest Windows 10 64 bit
September 23, 2020, 10:51:24 »
Карма: +3241/-85
Quote from: Southernwave on September 22, 2020, 22:52:43
Please try on this build:
https://yadi.sk/d/kwXmMS_4pw0I4w
it should generate extended report about the issue.
September 23, 2020, 12:07:23 »
Southernwave
Thank you ... loaded and ran .. and had a error and got the same message
Where will I find the error report ?
September 23, 2020, 12:58:09 »
Карма: +3241/-85
It should display it instead of error window. Can you attach screenshot of error window?
September 23, 2020, 23:07:19 »
Southernwave
This is all I get... as mentioned I have to END TASK via TASK MASTER or reboot to clear the error and unfreeze AIMP
September 25, 2020, 08:35:50 »
Карма: +3241/-85
https://yadi.sk/d/Te2mV5JLW3IBtQ
Reply #8 on:
September 30, 2020, 23:24:03 »
Southernwave
Sorry for the delay ...
I installed as suggested but still have the issue
I have noticed that the error is more likely to happen if I select a suggested result while the search is still happening
Reply #9 on:
October 06, 2020, 09:30:16 »
Карма: +3241/-85
Please try on following build:
https://yadi.sk/d/2jjFc3gx4wD_rA
