AIMP for Android v4.30
How could one copy all of the enabled tracks to a special folder?
Topic: How could one copy all of the enabled tracks to a special folder? (Read 1864 times)
September 04, 2020, 07:03:35 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
How could one (phyisically) copy all of the enabled tracks (e.g. 100 enabled of 1000 tracks) in a playlist to a special folder in a single step or two or so?
Oops, an answer from Soolo...gone...disappeared...just gone away...
Last Edit: September 04, 2020, 07:25:03 by Biff
Re: How could one copy all of the enabled tracks to a special folder?
September 04, 2020, 18:26:01 »
sveakul
Карма: +81/-1
You could "select all files" from the "..." button, then set a hotkey in the "Files: send to" section for the function "Copy to..". That should be 3 steps if you use the "set as default" after specifying the folder for the "Copy to" operation the first time. Unfortunately this wouldn't weed out just the "enabled" tracks, not sure if that can be done without selecting those manually first.
September 04, 2020, 18:47:29 »
Biff
Карма: +4/-0
Yes, weeding out is the problem. Copying is done easily, just ALT+A and drag the tracks to a folder.
