AIMP v4.70, build 2227
Topic: AIMP v4.70, build 2227 (Read 2649 times)
September 01, 2020, 14:40:01 »
wynford
Карма: +2/-1
Went to install AIMP v4.70, build 2227 and widows 10 says this file may be harmful to your computer (or something like that), that has never happened before and it says it's a verified publisher... installed it anyways.
Re: AIMP v4.70, build 2227
September 01, 2020, 19:26:30 »
Карма: +3220/-78
What is your antivirus? What mirror you have uses for downloading?
September 02, 2020, 00:35:21 »
wynford
Карма: +2/-1
Windows Security and downloaded from AIMP
September 02, 2020, 01:04:23 »
wynford
Карма: +2/-1
I had more time now, I uninstalled AIMP and reinstalled it and didn't get that message... all is good
September 02, 2020, 07:42:39 »
Карма: +3220/-78
I have found a root of issue, link to the installer was http instead of https. Issue has been solved. Thank you
