Skin Editor, Skin Engine
Conditional Labels in a skin for Android
Topic: Conditional Labels in a skin for Android (Read 10616 times)
August 24, 2020, 08:25:33 »
mortalis
Hi.
Is it possible to set a conditional text in a
SkinnedLabel
element in the skin editor for Android?
For example, the skin has a label with
Text
set to
'%Artist'
, but when the artist tag of an audio file is empty, the text is empty.
I'd like to show
'Unknown'
in this case.
Thanks.
Re: Conditional Labels in a skin for Android
August 24, 2020, 09:52:20 »
Карма: +3227/-78
Yes, use the %IF macro:
Code:
[Select]
%IF(%Artist,%Artist,Unknown)
August 24, 2020, 10:23:32 »
mortalis
Thanks a lot.
Sorry, should've created the topic in the android section.
