Playlists and Playlist Window
Topic: Playlists and Playlist Window (Read 6585 times)
August 11, 2020, 17:20:43 »
urgatorbait
Sorry for another question from this noob....
I am so completely baffled over the whole playlist aspect of AIMP. I almost don't even know what to ask but I'll try.
1. It seems like every time I just want to play a song from my library it automatically creates a playlist for every single song for that artist. I don't want playlists for everything I play. Can I turn this off?
2. If I can't turn this off then will I end up with a gajillion playlists in my library files/folder?
3. If it IS going to create all these playlists then how can I get it to only put the songs I want in it instead of getting everything by an artist?
4. I am not grasping this whole "Default" and "Local Files" tabs in the playlist window. What is the difference between the two?
I think that might be it for now. Thanks so much! See attached screen shot.
Re: Playlists and Playlist Window
August 12, 2020, 18:47:29 »
JD
Карма: +109/-3
Options / Player / Music Library / Default Action. If I understand correctly you need "play selected"
August 12, 2020, 20:20:26 »
urgatorbait
Thank you. Yes, this did the trick.
