Song not playing audio (Android)
Topic: Song not playing audio (Android) (Read 6254 times)
August 10, 2020, 13:04:19 »
Kaitaki
Hi,
I just downloaded AIMP and loaded up a playlist. When I finish my first song, the next song doesn't play audio but the slider for the song still goes along. Any fixes?
Last Edit: August 10, 2020, 13:54:38 by Kaitaki
Re: Song not playing audio (Android)
August 10, 2020, 13:12:02 »
Choveka
Карма: +43/-7
What kind of files do you play? Can you upload an example?
August 10, 2020, 13:17:53 »
Kaitaki
I play mainly MP3 files. It sometimes happens and sometimes doesn't. Does it have anything to do with load times?
August 10, 2020, 13:26:39 »
Choveka
Карма: +43/-7
How did you added files to the playlist? Are you used a previously created playlist or you did added the tracks via "pus" button?
August 10, 2020, 13:31:36 »
Kaitaki
I added files from my device's local files and used the plus button.
August 10, 2020, 13:32:43 »
Kaitaki
I also added each song one at a time instead of importing a playlist.
August 10, 2020, 13:36:13 »
Choveka
Карма: +43/-7
Where are the files stored - on the internal or on the external storage?
August 10, 2020, 13:37:42 »
Kaitaki
Internal storage
Reply #8 on:
August 10, 2020, 13:50:38 »
Choveka
Карма: +43/-7
Look at Settings -> Sound -> Output -> Output Method -> Set from Auto to Audio Track
Reply #9 on:
August 10, 2020, 13:54:05 »
Kaitaki
It works now. Thank you so much
Reply #10 on:
August 10, 2020, 13:54:58 »
Choveka
Карма: +43/-7
You are welcome. Have a nice day
