MyCloud connection to Onedrive
Topic: MyCloud connection to Onedrive (Read 4357 times)
August 08, 2020, 10:10:16 »
Dana
Hello,
When I attempt to connect to Onedrive a screen comes up with many error messages.
It looks like another program has started - AXMPP.
Is this program necessary to connect to Onedrive?
If so, how do I configure it?
Thank you,
Dana
Re: MyCloud connection to Onedrive
August 08, 2020, 14:37:41 »
Карма: +3221/-78
What error messages?
August 08, 2020, 21:14:22 »
Dana
There are several. They seem to be coming from the AXMPP app.
Is the AXMPP app required to get the Onedrive authorization?
If so, how does AXMPP need to be configured?
Thank you,
Dana
August 08, 2020, 21:34:49 »
Dana
Here are the error messages in order as they appear:
A new background windows opens for XAMPP.
(1) AIMP window: http:/localhost/xampp/.
There is an "OK" button as well.
(2) AIMP window: http:/localhost/xampp/head.php.
(3) AIMP window: http:/localhost/xampp/start.php.
(4) AIMP window: http:/localhost/xampp/navi.php.
Then the XAMPP window disappears & returns to the AIMP Cloud Storage window without a token.
Thank you,
Dana
August 08, 2020, 22:01:29 »
Dana
Hello,
Solved the conflict. XAMPP is a Python Development environment I had installed quite awhile ago. Uninstalled the program and all is well.
Sorry for the confusion.
Dana
August 09, 2020, 08:07:43 »
Карма: +3221/-78
Ok, thank you for information.
