Suggestions
DennoN
New settings for duration of sound fading
Topic: New settings for duration of sound fading (Read 10447 times)
April 08, 2018, 17:07:39 »
xeo
Карма: +20/-0
Hi, is it possible to add control of some sound fading?
I'd like to be able to control the duration of sound fading at these options:
- Pause/Unpause
- Navigation within track
I always thought it's too short by default.
Re: New settings for duration of sound fading
April 08, 2018, 20:36:41 »
Карма: +3236/-85
You want increase the duration? I afraid it impossible to implement. Duraion of these effects are equal to size of internal buffer
April 09, 2018, 12:31:50 »
xeo
Карма: +20/-0
Which buffer? Maybe it can be changed.
April 09, 2018, 12:49:46 »
Карма: +3236/-85
Quote from: xeophyte on April 09, 2018, 12:31:50
Internal buffer, it cannot be changed
April 01, 2019, 22:23:47 »
xeo
Карма: +20/-0
Is it possible to change it in current version of libraries?
April 02, 2019, 08:35:55 »
Карма: +3236/-85
No
June 05, 2020, 22:21:51 »
Lombra
I have the same suggestion, only I would like to set it shorter than the default. Would that then be possible?
Suggestions
DennoN
