Is it possible to search songs based on the custom metadata tag?
Topic: Is it possible to search songs based on the custom metadata tag? (Read 2593 times)
May 12, 2020, 19:46:34 »
armennoik
I create a tag as a language tag for the file. However, it doesn't seem to be able for search.
does this function support? or any addon can solve the problem?
Thank you for any reply.
Re: Is it possible to search songs based on the custom metadata tag?
May 12, 2020, 19:50:12 »
Карма: +3225/-78
No, aimp does not load the tag fields that are not supported
