Suggestions
DennoN
AIMP for Windows: change playlist related order in contextual menu
Topic: AIMP for Windows: change playlist related order in contextual menu (Read 4463 times)
May 11, 2020, 11:55:52 »
𝗞𝗡𝗧𝗥𝗢
Карма: +76/-1
Hi! You can email me or contact me via Telegram.
Hello all,
I would like to make a minor suggestion in AIMP for Windows.
I would like to see the context menu items in this order:
Play
Add to playlist
Open in new playlist
Add to queue
Edit tags
Convert to other format
So, I only ask to switch second and third options, because I think the
Add to playlist
option is used much more often than the
option. At least, it is more useful, I think.
That's it. Thanks for reading!
Re: AIMP for Windows: change playlist related order in contextual menu
May 11, 2020, 13:08:02 »
CkopoxoD
Карма: +151/-1
You can customize the menu for yourself. Just disable integration, edit AIMP-ContextMenu.ini in Profile folder as you wish, then enable integration.
May 11, 2020, 20:52:44 »
𝗞𝗡𝗧𝗥𝗢
Карма: +76/-1
CkopoxoD
Thanks a lot! It works!
Suggestions
DennoN
