Instant time Pop up over the progress bar.
Topic: Instant time Pop up over the progress bar. (Read 2944 times)
May 03, 2020, 16:10:28 »
Sigmund
Hi there,
I'm using Aimp for podcasts too.
There is a mouse over popup showing the selected time on the seek bar, but it appears with a delay of nearly one second.
So when looking for a specific time, I sometimes have to wait multiple times.
VLC shows and updates that pop up instantly.
This is surely not a performance issue, it is a feature.
Is there any way to change that behavior?
Thanks.
Re: Instant time Pop up over the progress bar.
May 03, 2020, 17:22:18 »
gr-e
Карма: +169/-3
Click and hold the left mouse button while navigating the seekbar, you'll see a time display that's updated continuously
June 17, 2021, 14:43:12 »
heroclix
Карма: +8/-6
I would also like to request an option to make the time popup on the seek bar constant when you mouse over. I don't want any delay. I don't like holding down the left mouse button to seek the time.
