Artem, Is it possible to sort albums by year without creating additional tree layer?
There is an answer literally two posts above yours
With mentioned solution it's possible to sort only alphabetically...
The a>z and z>a are for alphabetical sorting, the third option disables alphabetical sorting. That's what you need to use.
Thanks for info. Please check my attached image, I've tried multiple variations... And all of them show incorrect order.So my question is - is it possible to sort albums similar like "1" from my attachment file, but sorted by year, without any "year" folders.
Are you sure your files are tagged properly?
Seems that thumbnail view is correct, but left tree view - not...
