Suggestions
DennoN
Option for disable hitns
Topic: Option for disable hitns (Read 3886 times)
February 24, 2020, 03:21:57 »
Eternal Themer
Завсегдатай
Карма: +4/-0
please an option to disable hints
Re: Option for disable hitns
February 24, 2020, 20:45:22 »
Карма: +3225/-78
It can be done via the HintHideDelay option that customized via config file. Please, refer to the Help \ Did you know that… \ Player \ Hidden Options
February 25, 2020, 16:12:43 »
Eternal Themer
Завсегдатай
Карма: +4/-0
done! HideHintPause=0 does the trick! thank you!!
Suggestions
DennoN
