Suggestions
DennoN
Audio converter option to move png/jpg art files
Topic: Audio converter option to move png/jpg art files (Read 3346 times)
February 16, 2020, 15:18:32 »
Hydro
Hello,
First, thank you so much for the play, by far the best
It would be great to have an option in the audio conversion tool that allows to move album art files that are in the same folder as music files, when files are outputted to another folder. One could specify the type of file (jpg/png) and add a filter for file name, and specify a output name for the images.
What do you think about the idea ?
Suggestions
DennoN
