Плагин UPnP (сервер)
Poll
Ваше мнение? / What do you think?
За / I need this option too
7 (70%)
Нейтрален / I don't care
3 (30%)
Против / Useless fo me
0 (0%)
Total Members Voted:
10
Pages:
3
All
Topic: Плагин UPnP (сервер) (Read 62213 times)
Re: AIMP DLNA Client (Alternate) [AIMP5]
Reply #30 on:
March 29, 2023, 17:23:59 »
Solarius
Здравствуйте!
Можно ли добавить в плагин или в плеер в целом, функцию "воспроизводить на устройство UPNP"? Таким образом, чтобы в списке досупных устройств вывода были рендереры в сети. Сейчас, чтобы поиграть с ноутбука на стационарную систему использую foobar с плагином. Очень удобная штука.
uPnP Media Renderer Plugin Request
Reply #31 on:
July 27, 2023, 11:30:57 »
doremo
Hi AIMP fans,
I've been a fan of AIMP since Winamp retired many years ago. I love the sound quality and user-friendliness of AIMP. However, I've noticed that there seems to be a lack of support for audiophile/hi-res quality output.
In recent years, audiophile systems have been moving towards wireless playback. While I agree that wired connections offer the best sound quality, network bandwidth is more than enough to send hi-res audio data to a network player with a DAC.
I would love to see AIMP add a UPnP Media Render feature or plugin. This would allow me to stream hi-res audio files from my computer to my network player without any loss of quality.
I believe that this would be a great addition to AIMP and would make it even more appealing to audiophiles.
Thank you for your time.
Re: uPnP Media Renderer Plugin Request
Reply #32 on:
November 01, 2023, 22:48:59 »
JD
Карма: +109/-3
Дельное предложение
Re: Плагин UPnP (сервер)
Reply #33 on:
February 24, 2024, 13:09:53 »
Alik
Активные колонки Edifise S1000W (30+кРуб., диффузоры алюминий и титан) подключаем по UPnP через foobar2000 и радуемся фонотеке, слушаем интернет радио с потоками до 1442, плагин для YouYube есть... Любимый AIMP давай UPnP плагин!?
Reply #34 on:
February 24, 2024, 15:32:40 »
Карма: +3179/-76
https://www.aimp.ru/?do=catalog&rec_id=1271
Reply #35 on:
September 25, 2024, 21:49:18 »
EvgenyVK
Пару раз прочитал тему, но не до конца все понял – слабоват в терминологии. Мне хотелось бы с ПК с помощью AIMP транслировать аудио (FLAC или, в крайнем случае, MP3) по локальной сети через медиаплеер IconBiT XDS1003D T2 на усилитель. Или же удаленно управлять воспроизведением файлов с IconBiT с помощью AIMP. Воспроизведение с самого медиаплеера для меня неудобно хотя бы потому, что необходимо включать телевизор и неудобно набирать списки воспроизведения пультом плеера. Файлы музыки есть соответственно и на ПК, и на медиаплеере. Сеть проводная через роутер. ПК и медиаплеер видят друг друга, файлы свободно копируются в обе стороны. Операционка на ПК Win 8.1 (6.3.9600), версия AIMP на сегодня 5.30.2563. Собственно вопрос – какой из плагинов ставить – AIMP DNLA Client от 2023-03-12 или AIMP DNLA от 2022-12-27? И какие настройки надо еще произвести в AIMP? И еще момент – мне было бы удобнее воспроизводить музыку именно с ПК по сети через IconBiT хотя бы потому, что проще и быстрее формировать плейлисты.
Reply #36 on:
September 25, 2024, 23:06:54 »
Карма: +462/-73
Для ваших целей нужен сервер, что плеер не поддерживает. Поэтому ни один плагин не подойдёт. Это неоднократно повторяется в той или иной форме.
У плагинов даже описание одинаковое, только авторы разные.
https://www.aimp.ru/?do=catalog&id=2&os=windows&V=0&F1=0&F2=0&keywords=dlna
Для сервера вам придётся найти другой софт. Например, Home Media Server.
Для вещания есть только плагин AIMP LanCast, а детали можете прочитать в обсуждении плагина. В большинстве случаев он не является хорошей альтернативой DLNA-сервера или вещания радио через VLC.
Reply #37 on:
September 27, 2024, 18:31:48 »
EvgenyVK
, спасибо за ответ. Действительно, почитав разные форумы, решил поставить HMS. Осталось как следует разобраться в настройках. Конечно очень жаль, что нельзя AIMP заставить "вещать" по сети на плеер. Уже лет 15 как пользуюсь AIMP для музыки и очень привык к его интерфейсу и скину Technics M253X (ностальгия по кассетным декам
Reply #38 on:
September 27, 2024, 19:45:45 »
Карма: +3179/-76
AIMP все-таки для прослушивания...
Pages:
3
All
