Suggestions
DennoN
[Feature Request] ability to custom rating algorithm
Topic: [Feature Request] ability to custom rating algorithm (Read 4529 times)
January 06, 2020, 13:23:47 »
Laster2800
Карма: +4/-0
I mean, user can write scripts to control how to calculate song rating, instead of simply calculating rating based on the ratio of playback count.
Last Edit: January 06, 2020, 13:53:24 by Laster2800
Re: [Feature Request] ability to custom rating algorithm
January 06, 2020, 13:26:58 »
Карма: +3221/-78
What algorithm you want to implement?
January 06, 2020, 14:12:32 »
Laster2800
Карма: +4/-0
Quote from: Artem on January 06, 2020, 13:26:58
For example: Actively clicking to play a song from the music library, or adding a song to the queue should greatly increase the rating. Stop to play next or another song should greatly reduce the rating.
At least, I hope user can process the default output: access every song's original rating in one song's rating processing, and use basic mathematical operations such as [+, -, *, /, %] to process.
And I think there should be a "random" playback mode based the rating or user rating, in which songs in higer rating should be played more.
January 06, 2020, 15:09:43 »
Карма: +3221/-78
I afraid it impossible to implement using API
January 06, 2020, 19:23:03 »
Dreamer
Завсегдатай
Карма: +12/-0
I'd call it automatic or intelligent rating. I thought about it too.
Anyway, if it would be implemented somehow, it should ignore manually rated songs.
Suggestions
DennoN
