AIMP v3 Android crashes with custom skin
Topic: AIMP v3 Android crashes with custom skin (Read 10592 times)
January 06, 2020, 06:47:47 »
kakamal
Hi everyone, newbie here. Well I'm using AIMP on my Android Auto and really love it. It's very light and fast loading not like some other players. But I prefer bigger album cover the like of Spotify which is not available with default Skin.
I have downloaded several custom skins for android/for CarPC but whenever I tried to load it the AIMP crashes to home screen. I have followed the instruction on this page
https://www.aimp.ru/files/how_to_install_addons_lang-en.txt
. But I don't understand where should I upload it.
Thank you in advance.
Re: AIMP v3 Android crashes with custom skin
January 06, 2020, 13:04:53 »
Карма: +3224/-78
What skin you have installed?
January 07, 2020, 05:52:40 »
kakamal
Hi @Artem thanks for the reply. I have installed Charm Illusion and Polaroid V2 but both crashes on my Android Head Unit. I can installed on my phone without any problem though.
January 07, 2020, 09:49:35 »
Карма: +3224/-78
What is installed on your head unit?
January 08, 2020, 06:20:46 »
kakamal
Hi @Artem plenty of apps but for the music apps I've got Spotify, Google Music and AIMP only.
Well actually I kind of like your Pandemic (AIMP v1) default skin but it would be great if the song and artist title can be moved below or on top of the album cover (pic attached). The current Song and Artist title is way too small and located at the wrong place until you have no idea what song is currently playing. Thanks
Last Edit: January 08, 2020, 07:00:02 by kakamal
January 14, 2020, 11:53:46 »
kakamal
Hi there @Artem. I have uninstalled the app as adding skin makes the app crashes to desktop. However I have failed to reinstall the app as it gives me error. AIMP: A critical error has occurred. Please send the following bugs reports to our email.
January 14, 2020, 21:48:34 »
Карма: +3224/-78
Make sure that you installing app to phone memory, not sd-card
January 15, 2020, 05:04:43 »
kakamal
Thanks @Artem for the reply. Well this error happened on my Android Head Unit which I had no problem installing previously. AIMP does not gives any option in which location to install though. I unplugged my USB stick (mp3) and reinstall the AIMP but still encountered the same error.
Reply #8 on:
January 15, 2020, 12:23:43 »
kakamal
Ok I have noticed in my system there's T3 Portable storage which I've no idea came from where (after firmware upgrade) as I did not hook up any portable storage on it. Any installed apps goes to this storage instead of the internal storage. The rest of the apps are running fine except AIMP. Appreciate if you could provide a solution for this because I really love this AIMP. Thanks.
