Suggestions
DennoN
Custom presets with different options
Topic: Custom presets with different options (Read 6828 times)
November 15, 2019, 19:40:32 »
Dreamer
Завсегдатай
Карма: +12/-0
Some programs have this option - custom presets with different options.
I'd like to use different options for different purposes and switch them easily, with a keyboard shortcut, menu item...
Currently I have to change all these options manually in Settings window and it's not easy, since I need to switch it often.
Here are the examples for 2 presets:
1) Speakers 5.1
- enable Allow channels mixing - Stereo -> 5.1 Surround
- playback option - parameters - 5.1 Surround
- Volume - set to 60%
2) Headphones
- disable Allow channels mixing - Stereo -> 5.1 Surround
- playback option - parameters - Stereo
- Volume - set to 90%
Alternative is to use the command line options / parameters for these options, or/and for presets activation.
Workaround I'm thinking about is to use 2 separate portable folders / "installations", just use few different settings, is it possible to use AIMP this way? 2 folders, 2 icons...?
Suggestions
DennoN
