Suggestions
DennoN
[Android] Option to disable the sort handles in the list of playlists
Topic: [Android] Option to disable the sort handles in the list of playlists (Read 4835 times)
October 07, 2019, 12:51:27 »
rmf
I'm left handed, and when I try to scroll through my list of albums, I very often accidentally end up rearranging the list because I touch one of those handles instead of the album title.
It would be great if these could be disabled (as I believe was the case in older versions) or maybe moved to the right.
I've added a screenshot with the handles circled in red to make sure there's no confusion as to what I'm talking about.
Re: [Android] Option to disable the sort handles in the list of playlists
October 07, 2019, 13:01:17 »
Карма: +3229/-78
Just enable playlist auto-sorting.
October 07, 2019, 13:05:15 »
rmf
Thanks for the fast reply!
The auto sort does disable the handles, but I don't have my playlists sorted alphabetically. They're sorted mostly by genre and with some podcast directories up top, and that goes away if I use auto sort.
October 07, 2019, 13:17:02 »
Карма: +3229/-78
Yep, it does not.
You can disable (remove) handles only on skin level.
Suggestions
DennoN
