Change Caption Area display Bliss 4K
Topic: Change Caption Area display Bliss 4K (Read 3511 times)
September 08, 2019, 02:49:55 »
Southernwave
Apologies for (what I think is ) a very silly/easy question
I have been attempting to get my head around editing the skin in AIMP...currently I have a version of the basic Bliss 4K set up (almost the ) the way I like it.
Bur I would like to change the information diplayed in the Caption Area of the player.
Currently there is the track title ... which is in bold...and then under that are 3 lines being ...Artist then Album then File information (ie FLAC 44.1 khz 647 kbps Stereo).
Somewhere in that lot I would like to include the Composer... happy to replace the second line or the third.
I have looked in the editor.. tried lots of things... but failed.
Could some one give me a hint ... or better still a solution ?
Much appreciated
Andrew
Re: Change Caption Area display Bliss 4K
September 08, 2019, 03:03:00 »
17hapi
Карма: +73/-0
September 08, 2019, 04:06:01 »
Southernwave
Thank you for the quick reply
I had tried that and no change.
Does this mean the the skin doesnt support this feature ... and is there a way of adding the support ?
A
September 08, 2019, 09:10:12 »
Southernwave
I went back to the original Bliss 4K and the changes work... seems I must has messed things up when I added visualisation to the player bar...proves I am really having trouble getting my head around the Skin editor.
Back to the drawing board.....grrrr
September 08, 2019, 12:51:23 »
gr-e
Карма: +170/-3
Download the latest skin editor, open the Bliss 4K project and look how these text boxes are connected to the prvPlayingFileInfo provider. Also, the "Template" property may be different as well.
