AIMP for Android v4.30
Suggestions
DennoN
Aimp (Android) tagger, album cover and lyrics
Topic: Aimp (Android) tagger, album cover and lyrics (Read 7451 times)
August 12, 2019, 08:14:27 »
Nodscene
Will we get the ability to change the .mp3 info and album cover in the Android version soon...please
It would be a bonus to add lyrics either manually or through a service (same goes for mp3 tagging I guess). The reason I'm asking for this feature as I actually use Aimp on my phone a lot more than my computer. This way it would allow me to make whatever changes I need done right away before it drives me crazy or forget.
I don't understand coding but if you can get write privileges to the .mp3 file I'm hoping it would be easy from there. The easiest way may be to do it through the file info area but that would need a fairly major overhaul to be able to do . mp3 tagging let alone album art (and very low on my requests is lyrics).
As I said,, I'd be happy to just be able to do all that manually which will hopefully make the programming much easier.
I'm sure I'm not the only one who would love this feature on Android.
Lastly, I'd love to say thanks for a great program as I've been using the Windows version for years (where it was almost impossible to find any English) and I consider it one of the best ones on the market. I really appreciate your dedication to audio quality as well as that is a big thing for me.
I appreciate all.your hard work and was really happy when I was able to use it on my android and use a Scrobbler as well.
Cheers from a long time fan.
Suggestions
DennoN
