nostromos, Svetlana Saz and 2 Guests are viewing this topic.
Recommend after realize authorization add option mark-watched for Yotube when finished listen (maybe with percent detected).I guess this is better than passing a mark only to Last.fm, where scrolling of video titles is not guaranteed.
Incorrect first track name (when add list/user)...v0.4 + yt 2019/07/27https://www.youtube.com/channel/UC38GMKiSwiZQQITrRYuTEOAFirst name after add "► Play all", after start "Nightcore - Wide Awake (Kelypso)"https://www.youtube.com/user/08yakari and UUUCeZaZeJbEYAAzvMgrKOPQ"► Play all", second "米津玄師 MV「海の幽霊」Spirits of the Sea".
AIMPUI_FORM_PROPID_STYLEЕсли плагин построен на apiGUI - он заработает сам, режима совместимости нет.
Are you planning to change the GUI settings to the player's API with support for night design?
Also, it seems that the verification code of the program used is not used. AIMPac and AIMPate report an error when checking the plugin and upload it to unstable. AIMP 4.6.0.2144
i could just change the colors around based on that, but i have no idea where to get such information.
What verification code? What is AIMPac or AIMPate?
Initialize in Core IAIMPCore Reference to the basic interface out Result HRESULT Note that plugin can be loaded by Audio Converter or Tag Editor tool. You should check on plugin initialization if all required built-in services are available. If some services are not available plugin may return an error code - AIMP will mark this plugin as unused.S_OK - if success, other value otherwise.Warning! The Finalize method will not be called, if this function will return value different from S_OK.Refer to the "Guidelines for working with services"
Coub? Not supported yet?
...CorusCoubCracked...
dark mode support (based on NightMode in AIMP.ini) - it's not perfect but close enough, checkboxes/comboboxes unfortunately can't be easily styled in winforms
Tested it with 100/125/150% DPI and it seems to work.
