Suggestions (archive)
Implemented in AIMP v4.60
[Реализовано] Playing WebM files via basswebm.dll plugin vs. ffmpeg
Topic: [Реализовано] Playing WebM files via basswebm.dll plugin vs. ffmpeg (Read 7005 times)
July 02, 2019, 22:54:31 »
sveakul
Карма: +81/-1
This is just something I tried that might be interesting to others. AIMP supports *.webm files fine since it added the ffmpeg plugin a while back. I just noticed that the BASS library people at un4seen have posted a "First Release" BASS plugin that also supports *.webm:
http://www.un4seen.com/stuff/basswebm.zip
I made a folder in AIMP's plugin directory named "bass_webm", and extracted the 32-bit basswebm.dll from the zip into it, and renamed it "bass_webm.dll" to follow AIMP's convention.
Then I disabled the AIMP ffmpeg plugin, restarted, and tried playing a *.webm file containing Opus audio. It played just fine! It also worked with a *.mka audio file, as the plugin's specs advertised.
So, it just proves that there is an alternate method now to support *.webm and *.mka in AIMP. Whether it has any drawbacks or advantages over just using the ffmpeg plugin I have no idea.
Last Edit: July 20, 2019, 15:35:59 by Artem
Re: Playing WebM files via basswebm.dll plugin vs. ffmpeg
July 03, 2019, 08:56:02 »
Карма: +3233/-82
Thank you, I will test this plugin. Also, FFmpeg used to play ATRAC3 audio files.
July 18, 2019, 22:54:22 »
sveakul
Карма: +81/-1
Working great in build 2137, and what a difference in size! Thanks!
