Suggestions
DennoN
middle mouse button click
Topic: Queue toggle keyboard shortcut / middle mouse button click (Read 2914 times)
April 21, 2019, 01:36:51 »
Dreamer
Продвинутый
Карма: +12/-0
Middle click to add the file to queue is useful and fast, but when I click it twice (by mistake), the same file is added multiple times and removing file from queue is not so easy.
I suggest to make the middle mouse button click the toggle button, also the Queue keyboard shortcut, so when 1 file is selected and I middle click once, the file will be added to queue, when I middle click again, remove the file from queue.
Alternatively, option to prevent adding the same file multiple times would be helpful and would solve this problem too.
Re: Queue toggle keyboard shortcut / middle mouse button click
April 21, 2019, 11:03:14 »
CkopoxoD
Карма: +72/-1
Quote from: Dreamer on April 21, 2019, 01:36:51
Hm... Ctrl+Q, middle click to remove (or use arrows to select, Del)
April 21, 2019, 13:57:44 »
Dreamer
Продвинутый
Карма: +12/-0
It's not the same, because I have to select the file first and then use the keyboard shortcut, which I'm not using often, moreover, I have to use both hands.
Suggestions
DennoN
