AIMP for Android v4.30
Suggestions
DennoN
Help with AIMP - Shuffle for single playlists but not for all
Topic: Help with AIMP - Shuffle for single playlists but not for all (Read 8050 times)
April 20, 2019, 12:38:23 »
DeerDance
Карма: +1/-0
I just started using AIMP and I created a few smart playlists. Is there a way to activate shuffle for specific playlists but not for everything? I have a playlist for audiobooks and albums which should play in order, but playlists with mixed music should be shuffled.
Re: Help with AIMP - Shuffle for single playlists but not for all
April 20, 2019, 15:49:08 »
Карма: +3207/-77
It was implemented in v2.90 beta
April 20, 2019, 16:59:09 »
Dreamer
Завсегдатай
Карма: +12/-0
Where is it, or how to use it? I couldn't find it in Options, menu.
When I enable it for one playlist, it's enabled for all, when I disable it for one playlist, it's disabled for all.
My version is 4.51, build 2073, Windows 10 1809.
EDIT: OK, so I found, that v2.90 beta is the Android version, so is it possible also in the Windows version? If not, could you implement it, please? Should I create a new topic in the Suggestions forum?
Last Edit: April 20, 2019, 17:56:28 by Dreamer
April 20, 2019, 20:24:40 »
gr-e
Карма: +169/-3
Yes please
Suggestions
DennoN
