Suggestions
DennoN
Rename File
Topic: Rename File (Read 6309 times)
Rename File
March 30, 2019, 22:44:26 »
vanisk
idk if its suggested before (tried to find it, but couldnt).
In File Info (F4), it opens Tag Editor
On clicking Rename or pressing F2, rename bar appears with name of file selected.
But it will be nice, if there is only name of file displayed (without path), so that we can Select all and type New name, or Press Home key to goto the first character
(or)
While pressing Left arrow key (when name of file is selected with path displayed), Move the cursor to beginning of file name.
Re: Rename File
March 31, 2019, 11:03:43 »
Карма: +3227/-78
In current case, you can move file to other folder if needed
Re: Rename File
April 01, 2019, 02:37:58 »
vanisk
Thank you for clarifying. Just now tested it. Great.
Suggestions
DennoN
Rename File
