[+] [722] Playlist "Icons" on home screen - shows "Removed"
Topic: [+] [722] Playlist "Icons" on home screen - shows "Removed" (Read 6969 times)
March 20, 2019, 02:13:52 »
RE:Specto
Карма: +1/-0
Dear Artem and AIMP team members,
first of all, I highly appretiate your work! it is a great player in many aspects, and right now I consider it as my first option for android music playback.
Recently, I was pleasently surprised to discover the ability to add a playlist to the home screen, by long-pressing the aimp icon, dragging the list, and dropping it as an icon.
Unfortunately however, after adding all my playlists to my home screen, I discovered that most of them are greyed out, do not play, and shows "Removed" when I press on them.
all that playlists do work perfectly when accessed from within the player. when I change the order of playlists inside the player, some of the home screen icons suddently starts to work, while others, ones that worked before, are no longer accesable, showing the same "Removed" message when I press on them. Screenshot attached.
I really hope this can be fixed, as I think of it as a feature of great importance for the AIMP player.
Respectfully
Johnny
Last Edit: March 20, 2019, 13:40:05 by Artem
Re: [722] Playlist "Icons" on home screen - shows "Removed"
March 20, 2019, 13:40:00 »
Карма: +3210/-78
This is limitation of Android, each application can have limited number of shortcuts (the maximum value is depended from firmware), usually maximum value is about 5-7 shortcuts per application.
Re: [+] [722] Playlist "Icons" on home screen - shows "Removed"
March 20, 2019, 16:07:24 »
RE:Specto
Карма: +1/-0
hmm.. that's unfortunately bad news for me..
maybe it is possible to implement in a widget? I"ll be glad to beta-test
