Suggestions
DennoN
Increase the cache size
Topic: Increase the cache size (Read 7852 times)
March 02, 2019, 21:26:37 »
freegg
Hi friends,
AIMP's great. But I personally have one problem while using it.
My harddisk makes loud noise when reads and writes. Every time AIMP loads a song, the harddisk yells.
Currently I've set the cache size to 250MB, I wonder if there's a way to break this limit so I can load the whole file/playlist once and keep it in the memory. I've got 64GB mem so it should be sufficent to load any lossless formats.
Thanks in advance.
Last Edit: March 02, 2019, 21:36:45 by freegg
Re: Increase the cache size
March 03, 2019, 02:05:24 »
data78
Well. Get a new HD as soon as possible. Reason why i tell you that is because your HD will fail and die. Theres nothing else you could do.
March 03, 2019, 10:20:18 »
freegg
Thanks for your advice.
The HD is under a 5 year warranty, passes SeaTools tests and I've got all files backuped to the cloud. So I'm not considering upgrade it now.
Suggestions
DennoN
