Questions (archive)
[Solved] Message: Command line encoder process is terminated
Topic: [Solved] Message: Command line encoder process is terminated (Read 42637 times)
January 22, 2019, 14:14:34 »
J.D.M
Can anyone tell me why I'm having this error "Message: Command line encoder process is terminated" when converting a lossless song to m4a (iTunes) or any other audio format. This error appeared in the last updates of the AIMP, being that previously I was able to format any track for m4a.
I already tested the Beta version and the error persists, I just do not go back to the version in which the conversion to m4a was working, as I do not know which version the conversion was working on.
Last Edit: January 26, 2019, 20:24:21 by Artem
Re: [ERROR] Message: Command line encoder process is terminated
January 22, 2019, 17:40:44 »
Карма: +3222/-78
Does installed QAAC encoder works from command line? May be required for it libraries were not installed or installed incorrectly
January 22, 2019, 20:04:11 »
J.D.M
I was taking a look and found out that I had not downloaded the "CoreAudioToolbox v7.10.9.0 portable" file from the audiophilesoft site. I always down the file, extract it and send the "qaac" folder into the encoders folder.
Now everything is working as it should. Thanks a lot for the help. I like AIMP because it uses all the cores of the PC in the formatting of the songs.
http://audiophilesoft.ru/load/coders_utils/qaac/7-1-0-50
Questions (archive)
