Click the File Types button
It doesn't quite make sense to me that I'm unable to decide what file types to be imported from within the application itself.
What you mean?
What your documentation looks like https://ibb.co/hZp9eT, with the checkbox.What the current build looks like https://ibb.co/mL8rto.
Oh, I think I must update the screenshot. Dialog that displayed here was available for Windows XP in one of old versions. New Windows version forces applications to use system dialog for file associations
However, when I import from my folder .wav files are still imported.
What you exactly mean here? When you double click on these files it still opened in AIMP?
No, I don't mean clicking on the files to play them. I mean operating within AIMP. In my folder, there is a bunch of mp3 files of actual songs, and a bunch of wav files for some sound effects. If you know about OSU! you'll know what I mean.
Why you think that file associations should be related to what file formats are supported by the player? This releates only for integration with Windows Explorer. Answering to your question, AIMP have no ability to filter folder's content by extension during one or few folders adding. But you can index all your files with Music Library and filter the content in it.
What I do to import the folder: https://ibb.co/m0QHZT.
Settings tab > skip file if...
