Published skins
Mareala2 [AIMP4.50]
Topic: Mareala2 [AIMP4.50] (Read 29954 times)
Mareala2 [AIMP4.50]
June 29, 2018, 01:14:29 »
amdpastrana
Завсегдатай
Карма: +54/-0
Mareala2
amdpastrana
| 2018-07-02 | 892 KB |
Platform
: Desktop
App Version
: v4.50 or newer
Form
: Horizontal, All-in-One
Tone
: Dark, Light, Middle
Surface
: Mat
Tags
: Touch, FHD
New UI - Media Control - Mini Player
+Equalizer Window
+Context Menu
+Current File Info
+Drop Wheel
+New UI Mini Player
+Now Playing Window
+Black & White Art Display option
+Skin Options
and change some icons
4k display is probably a problem
Sorry my bad Eng.
Last Edit: July 02, 2018, 09:38:20 by Artem
Re: Mareala2 [AIMP4.50]
July 10, 2018, 07:41:17 »
KannelUR
Карма: +1/-1
Хороший скин.Спасибо
July 10, 2018, 09:50:40 »
Aliaksei
Карма: +5/-5
Скин прикольный, спасибо
А можно избавиться от левой панели?
July 12, 2018, 15:01:02 »
Andreas Maker
Карма: +8/-0
Nice skin, but why you don't use WordWrap on Lyric Window?
July 14, 2018, 15:57:58 »
Savage123
Можно поправить чтобы иконка не перекрывалась с текстом в EQ?
July 20, 2018, 02:16:20 »
Shiro
When using 125%/120 DPI, there is a white line in the media library tab, and the playlist label is normal.
October 25, 2018, 19:44:52 »
ArtyRot
Карма: +4/-0
Hello, is there any chance to make the music list window to be more narrow please. Or to modify it?
November 05, 2019, 20:34:12 »
SomeDude11
Can you update this skin for the latest version of Aimp please? It doesn't work properly anymore with the new version. For example the Media library button and others don't work anymore.
Reply #8 on:
March 15, 2020, 21:21:21 »
amdpastrana
Завсегдатай
Карма: +54/-0
13% Completed
maybe it will take long..
Reply #9 on:
March 21, 2020, 15:32:15 »
amdpastrana
Завсегдатай
Карма: +54/-0
at home during coronavirus quarantine
Support request for Mareala2
Reply #10 on:
July 27, 2020, 09:36:56 »
Utgard-Loki
Does support requests go here- if I enter this
https://imgur.com/g2fSLxt
by holding Music Library I can't return to the navigation page. The left arrow button on the right top corner does nothing. I can delete the .ini file in the skins folder to return but it resets other skin options so it's not a permanent solution. Is this a incomplete feature or a bug? AIMP version 4.70 Build 2224.
Reply #11 on:
November 17, 2020, 16:34:25 »
ovalseven
Is there any way to remove the timer and show the artist in the alt mini player? Aside from that, this skin is perfect. Nice work.
Reply #12 on:
January 22, 2021, 19:08:50 »
ramagoodstart
Hi could please upload the skin project file, I'd like to use yours as a template to design my own!
Would really appreciate it!
Published skins
Mareala2 [AIMP4.50]
