Questions (archive)
Unable to play files from UNC path
Topic: Unable to play files from UNC path (Read 41588 times)
December 06, 2017, 12:38:21 »
dami
Карма: +1/-0
AIMP does not add files from UNC path to the playlist. E.g. when trying to add a folder \\192.168.1.x\mymusic\ through the Windows explorer context menu, it does nothing.
Another way - menu Open files, insert the path to the explorer window, select file(s), click Open - files are not added to the playlist.
AIMP v4.50, build 2048, Windows 10.0.16299.64
EDIT:
Must have been a glitch in my PC, after restarting the computer everything works fine and playing from UNC path is working as expected.
Last Edit: January 11, 2018, 22:36:12 by Artem
Re: Unable to play files from UNC path
December 06, 2017, 12:48:12 »
Карма: +1402/-189
check firewall and antivirus
December 06, 2017, 13:20:28 »
dami
Карма: +1/-0
I must confirm some issue exists and arises after playing few files/folders after restarting the PC.
I can play individual files from the UNC path through the context menu.
But when I try to play an UNC folder this way (Rightclick on a folder, select AIMP/Play), AIMP stops playback, clears the Default playlist but does not anything to it from the folder contents (which is the expected behavior - it does so when playing a folder from the local or mapped drives).
I have disabled the antivirus and firewall to no avail.
January 11, 2018, 21:59:48 »
dami
Карма: +1/-0
The issue has been resolved by upgrading to the latest version of Synology NAS firmware.
Questions (archive)
