Suggestions (archive)
Implemented in AIMP v4.50
[Planned] How may I reset the number of times a song was played?
Topic: [Planned] How may I reset the number of times a song was played? (Read 11372 times)
February 18, 2017, 04:19:05 »
wipeout01
Карма: +3/-0
Hello, I'm loving the version 4 of AIMP, however, I have a problem.
Let's imagine I have listened a song 3 or 4 times, but I did not listen it well... and I want to reset the number of times a song was played, and put it to zero.
foobar2000 allow this, you can reset all the statistics if you want, but I did not see this option in AIMP
Cheers
Last Edit: February 21, 2017, 23:27:47 by Artem
Re: How may I reset the number of times a song was played?
February 18, 2017, 09:43:26 »
Карма: +3222/-78
AIMP has an ability to reset all statistics for all files in data base only
February 19, 2017, 18:39:56 »
wipeout01
Карма: +3/-0
is not possible to reset a certain song in particular?
February 19, 2017, 18:44:39 »
Zhenya
Тестер 3-го уровня
Карма: +328/-8
Quote from: wipeout01 on February 19, 2017, 18:39:56
You can remove a file from the database and add it again.
But all the statistics of file will be deleted (not only playback count).
February 20, 2017, 00:49:29 »
wipeout01
Карма: +3/-0
that is a lot of work if you have to do the same with many songs... it would be cool AIMP allow to reset the play count. For example, in foobar2000 you have an option, that says... Playback statistics... Reset statistics... and that is all... you can reset everything.
I'm trying to switch to AIMP because the interface is very cool and the sound quality amazing... but, without the possibility to reset the statistics I have a problem.
If you could consider to add this option in future versions, it would be very cool.
February 20, 2017, 15:17:45 »
Карма: +3222/-78
I will implement this function for selected files in next version
February 20, 2017, 17:38:02 »
wipeout01
Карма: +3/-0
This is what I really like from AIMP, they listen the people. Thanks, seriously, thanks a lot.
As far as I know, all the russian software I've used is the best. Kaspersky, one of the best antiviruses. ABBYY, one of the best OCR software. FontExpert, one of the best font managers I've used in all my life. And AIMP a perfect player, they listen to the users.
Absolutely wonderful.
спасибо!
