Please try this build. The first restart should still fail because the older plugin version will be loaded.
00000001 0.00000000 [8868] pltupnp.cpp(200): 2018-10-11T08:29:26.031000000+03:00 [PLT_UPnP::Stop] INFO: Stopping UPnP... 00000002 0.00010160 [8868] plthttpservertask.cpp(436): 2018-10-11T08:29:26.031000000+03:00 [PLT_HttpListenTask::DoRun] WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED) 00000003 0.00178340 [8868] plttaskmanager.cpp(226): 2018-10-11T08:29:26.031000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A92B88] 0/50 running tasks 00000004 0.05135010 [8868] pltdatagramstream.cpp(83): 2018-10-11T08:29:26.081000000+03:00 [PLT_InputDatagramStream::Read] FINER: PLT_InputDatagramStream received 0 00000005 0.05156730 [8868] pltssdp.cpp(481): 2018-10-11T08:29:26.082000000+03:00 [PLT_SsdpSearchTask::DoRun] WARNING: PLT_SsdpSearchTask got an error (-20021) waiting for response 00000006 0.05184180 [8868] plttaskmanager.cpp(226): 2018-10-11T08:29:26.083000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A92B28] 3/0 running tasks 00000007 0.15097250 [8868] plttaskmanager.cpp(226): 2018-10-11T08:29:26.182000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A92B28] 2/0 running tasks 00000008 0.15153620 [8868] plttaskmanager.cpp(226): 2018-10-11T08:29:26.182000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A92B28] 1/0 running tasks 00000009 0.15165640 [8868] plttaskmanager.cpp(226): 2018-10-11T08:29:26.183000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A92B28] 0/0 running tasks 00000010 0.15218090 [8868] plthttpserver.cpp(140): 2018-10-11T08:29:26.183000000+03:00 [PLT_HttpServer::Stop] WARNING: NPT_CHECK failed, result=-20009 (NPT_ERROR_INVALID_STATE) [(NPT_ERROR_INVALID_STATE)] 00000011 0.15246500 [8868] pltdatagramstream.cpp(83): 2018-10-11T08:29:26.184000000+03:00 [PLT_InputDatagramStream::Read] FINER: PLT_InputDatagramStream received 0 00000012 0.15253539 [8868] plthttpservertask.cpp(179): 2018-10-11T08:29:26.184000000+03:00 [PLT_HttpServerSocketTask::Read] WARNING: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)] 00000013 0.15260071 [8868] plttaskmanager.cpp(226): 2018-10-11T08:29:26.184000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A92708] 0/0 running tasks
same behavior
Artem, if you could try to reproduce this and debug aimp internally I would appreciate it.
allocation number: 69795program up time: 4,31 stype: Thread Handlehandle: $e10access rights: $1fffffthreadId: $50f4processId: $5f9cprocess exe: D:\Projects\AIMP\AIMP4Windows\trunk\AIMP\Binary\AIMP.exemain thread ($649c):671cfe5a madExcept32.dll madExceptDbg 3805 CreateThreadCallback004b0e8b AIMP.exe madExcept 17620 HookedCreateThread7619e9f4 ucrtbase.dll _beginthreadex00cf79ae AIMP.exe AIMP.ML.PluginDataStorage 311 TAIMPMLPluginBasedDataStorage.Create00cfbb14 AIMP.exe AIMP.ML.Services 245 TAIMPMusicLibraryService.RegisterExtension0086ae7e AIMP.exe AIMP.Core 349 TAIMPCore.RegisterExtension0097a7e7 AIMP.exe AIMP.Plugins 657 TAIMPPluginPresenter.RegisterExtension00979bf9 AIMP.exe AIMP.Plugins 461 TAIMPPlugin.Initialize0097c2f5 AIMP.exe AIMP.Plugins 1000 TAIMPPluginManager.Load0097c37a AIMP.exe AIMP.Plugins 1015 TAIMPPluginManager.Load0097be1e AIMP.exe AIMP.Plugins 926 TAIMPPluginManager.ConfigLoad00df7813 AIMP.exe AIMPMain 1227 ConfigLoadPlugins00df7bd7 AIMP.exe AIMPMain 1259 TAIMPMainForm.ConfigLoad00df6d1e AIMP.exe AIMPMain 1060 TAIMPMainForm.Initialize00e19ba7 AIMP.exe AIMP 69 initialization74a78482 KERNEL32.DLL BaseThreadInitThunk
Anyway my debugging tool shows to me a leak of thread handle:
Please try v2.3.2.0
fixed
short line
Corrected in v2.3.2.1
Moshi0,Hello, I am attaching the espanol-AR.lng [Spanish (Argentina)] language file below for this wonderful plugin! Keep up that good work!
Hi all,I just installed AIMP and AIMP DLNA plugin. I also enabled media streaming on Windows Media Player to make my own PC a DLNA server. However I don't know how to cast my music files to DLNA renderer. My DLNA renderer is Yamaha R-N803 which is a DLNA renderer. When I use Windows Media Player, I can select "Cast to device" and select my Yamaha network receiver as the renderer. How can I do the same with AIMP and AIMP DLNA plugin?
Sorry for late reply.This plugins is not a control point so you cannot control the renders or servers, it is only a client that can browse content servers for aimp to play from.
