In v2.3.0.0 you can fine tune the values in configuration dialog.
v2.3.0.0:
Sorry about that. Please try v2.3.0.2
A small drawback - the focus doesn't go inside the plugin settings page with the Tab key.
Also you can edit (and delete) content in Log level field:Is it necessary?
Ok it works. Thanks. How can I now control playback from Android device? I tired aimp remote control - https://play.google.com/store/apps/details?id=com.invised.aimp.rc - but it can't see dnla.
the plug-in hinder close of the AIMPif I update plugin with drag and drop aimp_dlna.zip file to AIMP main windowand then press button "Restart now" - AIMP not restarted
I have not used this app but I guess it does not allow you to browse music libraries, only playlists. So you would need to create a playlist with songs from your dlna server on your pc first.
Can you tell me step by step how to create Playlist which looks similar to folder view in the dnla library?
Music Artist 1 Album 1 Album 2 Album 3 Artist 2 Album a Album b Album c
Didnt know you can update plugins like that. But I tried it and it restarts just fine for me.Are you sure its aimp_dlna and not some other plugin? Any steps to reproduce this issue?
Well, a playlist is a flat list of songs so it cant have folders.But you browse to a folder with songs you want, then right click on that folder, and you can add the songs to a playlist or create a new one.There is also a feature in the plugin that helps with this. You can browse all folders you want to include in your playlist, and then click on the parent folder and all browsed children songs will be included from cache.So for example if you have a tree:Code: [Select]Music Artist 1 Album 1 Album 2 Album 3 Artist 2 Album a Album b Album cYou can first browse "Album 1", "Album 2", "Album 3" folders so the songs get loaded into the cache.Then you can click on the "Artist 1" folder, and the plugin will fetch songs from cache for folders "Album 1", "Album 2", "Album 3" and combine them in one list.There is a configuration option to set how deep should the cache be included, it defaults to 2 so you could also click on "Music" folder and it will still load "Album 1", "Album 2", "Album 3" from cache.Hope I explained that good enough.
Sound bad. :/ Only in my folder view I remember where I have music which I want play at specified moment. It's easy to find albums and tracks. DNLA plugin allow me to use folder view. But aimp remote can't see dnla library. So there is a way to add to aimp remote feature which allow me to view dnla library?
if I select the DLNA tab - there is the problemif I select local files tab - so good
So if I understand correctly, when you click restart aimp closes but does not restart? I had this happen only once while testing so I cant reproduce this issue.Does this happen for you every time you want to update? Every time you click restart, aimp does not restart at all?If so, could you set debug level to FINEST in options, restart aimp, open DebugView from Sysinternals, and try to update again? Then please send me the last few lines from the log.
00000001 0.00000000 [772] pltupnp.cpp(200): 2018-10-10T16:27:19.767000000+03:00 [PLT_UPnP::Stop] INFO: Stopping UPnP... 00000002 0.00010330 [772] plthttpservertask.cpp(436): 2018-10-10T16:27:19.767000000+03:00 [PLT_HttpListenTask::DoRun] WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED) 00000003 0.00142060 [772] plttaskmanager.cpp(226): 2018-10-10T16:27:19.767000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00BDE908] 0/50 running tasks 00000004 0.05122430 [772] pltdatagramstream.cpp(83): 2018-10-10T16:27:19.818000000+03:00 [PLT_InputDatagramStream::Read] FINER: PLT_InputDatagramStream received 0 00000005 0.05140810 [772] pltssdp.cpp(481): 2018-10-10T16:27:19.818000000+03:00 [PLT_SsdpSearchTask::DoRun] WARNING: PLT_SsdpSearchTask got an error (-20021) waiting for response 00000006 0.05143710 [772] plttaskmanager.cpp(226): 2018-10-10T16:27:19.819000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00BDE758] 3/0 running tasks 00000007 0.16013400 [772] plttaskmanager.cpp(226): 2018-10-10T16:27:19.927000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00BDE758] 2/0 running tasks 00000008 0.16033690 [772] plttaskmanager.cpp(226): 2018-10-10T16:27:19.927000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00BDE758] 1/0 running tasks 00000009 0.16041949 [772] plttaskmanager.cpp(226): 2018-10-10T16:27:19.928000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00BDE758] 0/0 running tasks 00000010 0.17602541 [772] pltevent.cpp(123): 2018-10-10T16:27:19.943000000+03:00 [PLT_EventSubscriber::~PLT_EventSubscriber] FINE: Deleting subscriber (uuid:241948e5-43b3-4107-90d7-9497b0d5aef0) 00000011 0.17609809 [772] pltevent.cpp(123): 2018-10-10T16:27:19.943000000+03:00 [PLT_EventSubscriber::~PLT_EventSubscriber] FINE: Deleting subscriber (uuid:299a8804-3a3b-4458-99a9-076434548ed4) 00000012 0.17616110 [772] plthttpserver.cpp(140): 2018-10-10T16:27:19.943000000+03:00 [PLT_HttpServer::Stop] WARNING: NPT_CHECK failed, result=-20009 (NPT_ERROR_INVALID_STATE) [(NPT_ERROR_INVALID_STATE)] 00000013 0.17644520 [772] pltdatagramstream.cpp(83): 2018-10-10T16:27:19.944000000+03:00 [PLT_InputDatagramStream::Read] FINER: PLT_InputDatagramStream received 0 00000014 0.17649710 [772] plthttpservertask.cpp(179): 2018-10-10T16:27:19.944000000+03:00 [PLT_HttpServerSocketTask::Read] WARNING: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)] 00000015 0.17656150 [772] plttaskmanager.cpp(226): 2018-10-10T16:27:19.944000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00BDE518] 0/0 running tasks 00000016 0.23825841 [772] pltupnp.cpp(198): 2018-10-10T16:27:20.005000000+03:00 [PLT_UPnP::Stop] WARNING: NPT_CHECK failed, result=-20009 (NPT_ERROR_INVALID_STATE) [(NPT_ERROR_INVALID_STATE)]
00000001 0.00000000 [7740] pltupnp.cpp(200): 2018-10-10T16:30:00.383000000+03:00 [PLT_UPnP::Stop] INFO: Stopping UPnP... 00000002 0.00009830 [7740] plthttpservertask.cpp(436): 2018-10-10T16:30:00.384000000+03:00 [PLT_HttpListenTask::DoRun] WARNING: PLT_HttpListenTask exiting with -20021 (NPT_ERROR_CANCELLED) 00000003 0.00147750 [7740] plttaskmanager.cpp(226): 2018-10-10T16:30:00.384000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A88260] 0/50 running tasks 00000004 0.05863230 [7740] pltdatagramstream.cpp(83): 2018-10-10T16:30:00.441000000+03:00 [PLT_InputDatagramStream::Read] FINER: PLT_InputDatagramStream received 0 00000005 0.05881050 [7740] pltssdp.cpp(481): 2018-10-10T16:30:00.442000000+03:00 [PLT_SsdpSearchTask::DoRun] WARNING: PLT_SsdpSearchTask got an error (-20021) waiting for response 00000006 0.05891020 [7740] plttaskmanager.cpp(226): 2018-10-10T16:30:00.443000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A881A0] 3/0 running tasks 00000007 0.16363440 [7740] plttaskmanager.cpp(226): 2018-10-10T16:30:00.547000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A881A0] 2/0 running tasks 00000008 0.16383830 [7740] plttaskmanager.cpp(226): 2018-10-10T16:30:00.547000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A881A0] 1/0 running tasks 00000009 0.16391119 [7740] plttaskmanager.cpp(226): 2018-10-10T16:30:00.548000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A881A0] 0/0 running tasks 00000010 0.17951770 [7740] pltevent.cpp(123): 2018-10-10T16:30:00.563000000+03:00 [PLT_EventSubscriber::~PLT_EventSubscriber] FINE: Deleting subscriber (uuid:bd609199-def1-428b-ac84-1a794068ce43) 00000011 0.17958499 [7740] pltevent.cpp(123): 2018-10-10T16:30:00.563000000+03:00 [PLT_EventSubscriber::~PLT_EventSubscriber] FINE: Deleting subscriber (uuid:bd37ab2c-83d7-477f-a129-c5c65a72e581) 00000012 0.17964870 [7740] plthttpserver.cpp(140): 2018-10-10T16:30:00.563000000+03:00 [PLT_HttpServer::Stop] WARNING: NPT_CHECK failed, result=-20009 (NPT_ERROR_INVALID_STATE) [(NPT_ERROR_INVALID_STATE)] 00000013 0.17993189 [7740] pltdatagramstream.cpp(83): 2018-10-10T16:30:00.564000000+03:00 [PLT_InputDatagramStream::Read] FINER: PLT_InputDatagramStream received 0 00000014 0.17998920 [7740] plthttpservertask.cpp(179): 2018-10-10T16:30:00.564000000+03:00 [PLT_HttpServerSocketTask::Read] WARNING: NPT_CHECK failed, result=-20021 (NPT_ERROR_CANCELLED) [(res)] 00000015 0.18005550 [7740] plttaskmanager.cpp(226): 2018-10-10T16:30:00.564000000+03:00 [PLT_TaskManager::RemoveTask] FINER: [TaskManager 0x00A88380] 0/0 running tasks 00000016 0.24176890 [7740] pltupnp.cpp(198): 2018-10-10T16:30:00.625000000+03:00 [PLT_UPnP::Stop] WARNING: NPT_CHECK failed, result=-20009 (NPT_ERROR_INVALID_STATE) [(NPT_ERROR_INVALID_STATE)]
