Suggestions
DennoN
Playing playlists when opening them in Windows explorer
Topic: Playing playlists when opening them in Windows explorer (Read 12451 times)
November 22, 2016, 20:40:15 »
Utumno
AIMP playlists can be played by double clicking on the playlists in Windows explorer, however in AIMP this does not play the currently existing playlist, it creates an identical new playlist with the same name and plays that instead. As a result, you can end up with a large number of identical cloned playlists cluttering up the playlist bar.
My suggestion for an improvement is to get AIMP to check if a playlist already exists in the program when opened, and if it does to play that playlist rather than creating a new one.
Thanks, and keep up the good work!
Re: Playing playlists when opening them in Windows explorer
November 22, 2016, 20:50:19 »
Карма: +3222/-78
What reason to import playlist from Windows Explorer again, if it alread imported to the player?
November 24, 2016, 17:48:40 »
Utumno
The reason I'd like to see this is because if you could re-open the playlist from windows explorer, I can also open them from the start menu. This would mean you could very quickly switch playlists even when AIMP is minimised to the system tray
November 24, 2016, 18:46:37 »
Карма: +3222/-78
AIMP does not store information about source file name that has been imported, so player don't know if importing playlist was already imported some time ago.
Suggestions
DennoN
