Questions (archive)
AIMP freezing keyboard input while loading next song [SOLVED]
Topic: AIMP freezing keyboard input while loading next song [SOLVED] (Read 4871 times)
October 17, 2016, 18:52:29 »
larsostli
I've got my library of 18 000 songs in AIMP, located on an external file server.
It handles the library well and is an excellent player overall, except one huge problem.
Whenever the player loads the next song either by finishing the last one, or me pressing the next button, every keyboard and mouse input is frozen until the song is loaded. File types are 320kbit MP3 with a 300mbit wireless connection between desktop and file server.
This is a bit of a hassle as I cannot use this player while playing games at all. It seems like AIMP is freezing the whole system, as mouse/keyboard inputs done while it's frozen will all come at once after it's done freezing, but 3D rendering and sound isn't freezing at all. CPU usage isn't going above 45% while loading songs, and RAM is only at 50% usage.
Does anyone know what this might be caused by? I really don't want to go to another player as I love the rating system and overall design of AIMP. Perfect player otherwise.
Info/specs:
AIMP v4.11 Build 1841
Windows 7 SP1 x64 (Build 7601)
Intel Core i5-3470 @3,4GHz Quad Core
16GB DDR3 1600MHz RAM
Nvidia GeForce GTX 680 2GB
Realtek High Definition Audio soundcard
Edit: I didn't know where to post this as every forum category was in Russian, feel free to move it of course.
Last Edit: October 17, 2016, 19:52:22 by Soolo
Re: AIMP freezing keyboard input while loading next song
October 17, 2016, 19:19:28 »
Карма: +3239/-85
Please, try to remove or rename the Multimedia Hotkeys Helper module that located in C:\Program Files (x86)\AIMP\System\aimp_mediakeys.dll and try to reproduce an issue.
October 17, 2016, 19:28:05 »
larsostli
That fixed the issue, much appreciated.
Thank you!
Questions (archive)
