AIMP for Android v4.30
Questions (archive)
Precise playlist
Topic: Precise playlist (Read 3147 times)
Precise playlist
October 04, 2016, 11:44:34 »
Panayotis Kritidis
Карма: +49/-0
Is a more precise playlist possible?
Dear friends, is it possible to construct a "precise" playlist, by use of start and end times within a given file? Let's say I have a 47 min classical music recording and I want to play only a part of it, starting at 14:37 and ending at 24:03.
If this is already possible, please show me the way to do it. Is it is not, why not consider the possibility to introduce it?
Всего хорошего!
P. Kritidis,
Athens, Greece.
Last Edit: October 14, 2016, 20:12:45 by Tarik
Re: Precise playlist
October 04, 2016, 15:25:22 »
Карма: +3200/-77
Hello,
I afraid that AIMP has no special functionality to do that. But, as workaround, you can try to use
CUE sheets
to divide real audio file to few virtual parts by specified time range
October 04, 2016, 19:55:18 »
Panayotis Kritidis
Карма: +49/-0
Thank you. This could be a good solution!
Questions (archive)
Precise playlist
