Suggestions (archive)
Implemented in AIMP v4.50
[Planned] AIMP Audio Converter
Topic: [Planned] AIMP Audio Converter (Read 6985 times)
September 01, 2016, 20:36:49 »
SCUBA
I use the Audio converter very often. I'd enjoy if the converter would close itself automatically after converting files.
A simple option would be great, thank you !
Last Edit: April 25, 2017, 21:21:16 by Artem
Re: AIMP Audio Converter
September 01, 2016, 20:42:02 »
Карма: +3224/-78
Thanks for your suggestion, we will consider it when planning new version. I have put it to our TODO-list.
April 21, 2017, 11:43:33 »
SCUBA
Well - i suggest one more time, hoping you can add that option thank you
