RAG and 1 Guest are viewing this topic.
Can you make accent color on selected tab (only text) https://i.imgur.com/L7O66A6.png?
I suggested the same, but the developer has answered that at the moment it's not possible. Only the text of playlist tab can be highlighted.
If you have arranged the above example, then you can do, perhaps you misunderstood me, that I compared with the standard Charm player
Please see the video... The accent colour of the text of the tabs do not change (they don't get highlighted). I mean, the selected text of the tab stays white, instead of turning orange.https://imgur.com/a/fTxUPMc
I already understood that you want this https://imgur.com/7TwcMbT, I think I'll do it
Обнаружил баг. В мини режиме не работает кнопка включения предыдущего трека, то есть я нажимаю на нее, а мне включает наоборот следующий трек
A minor request.I would appreciate that the pause button is highlighted when it is pressed. It rather looks odd, that the taskbar shows "pause" but the player interface does not show "pause".At the moment only the play button is highlighted when audio is played. I think it would look good that pause button is also highlighted when audio is paused.Thank you very much.https://imgur.com/a/t0tqJig
В стандартном скине реализовано так же, вы можете в настройках переключить мультимедийные кнопки в компактный режим, хотя будет тоже самое. Я не знаю почему так реализовано в панели задач и в панели уведомлений.В моем скине все просто, если файл воспроизводится то кнопка плей окрашивается в акцентный цвет, если нет то монохромная.In the standard skin it is implemented the same way, you can switch the multimedia buttons to compact mode in the settings, although it will be the same. I don't know why it is implemented this way in the taskbar and in the notification bar. In my skin everything is simple, if the file is playing, the play button is painted in an accent color, if not, it is monochrome.
А как включить визуализацию в этой теме?
