Visualizations
Analog Meter (скины для плагина)
Pages:
20
21
22
23
54
Topic: Analog Meter (скины для плагина) (Read 2432101 times)
0 Members and 39 Guests are viewing this topic.
Re: Analog Meter (скины для плагина)
Reply #300 on:
June 02, 2017, 14:28:55 »
sonivoir
Карма: +1/-1
+1 with a great thanks go to
Panayotis Kritidis
and
G121121
Finally i've created a VU plugin with the colors i always wanted.
I invite you to have a rest for
6
minutes.
If somebody needs it, may him write here (even in russian) and i will make a link.
I have also made another 8 remakes from the plugins published here, and i don't know
to show you or not.
I've also entered the topic xrEngine began and really expect that he will give birth to
another a better creation.
Thank you all and may God bless you.
Reply #301 on:
June 03, 2017, 19:55:12 »
G121121
Карма: +895/-68
Scott alpha 6
Last Edit: June 05, 2017, 18:27:42 by Soolo
Reply #302 on:
June 06, 2017, 22:28:57 »
G121121
Карма: +895/-68
Philips (пришлось рисовать с очень плохой фотки-в ФШ совсем не асс-как получилось)
Last Edit: September 07, 2017, 10:57:40 by G121121
Reply #303 on:
June 09, 2017, 15:56:15 »
G121121
Карма: +895/-68
vst deluxe (сделаю несколько vst-шек, если по шее не дадут)
перегруз загораться не будет (увы)
Last Edit: June 09, 2017, 16:04:41 by Soolo
Reply #304 on:
June 09, 2017, 16:29:26 »
G121121
Карма: +895/-68
vst retro
Last Edit: June 13, 2017, 08:22:10 by Soolo
Reply #305 on:
June 09, 2017, 17:12:15 »
G121121
Карма: +895/-68
vst black
Last Edit: June 13, 2017, 08:24:21 by Soolo
Reply #306 on:
June 09, 2017, 17:52:55 »
G121121
Карма: +895/-68
vst classic
Last Edit: June 13, 2017, 08:26:16 by Soolo
Reply #307 on:
June 09, 2017, 18:21:35 »
G121121
Карма: +895/-68
vst white
Last Edit: June 13, 2017, 08:28:25 by Soolo
Reply #308 on:
June 10, 2017, 14:22:28 »
G121121
Карма: +895/-68
sony 2
Last Edit: June 13, 2017, 08:29:56 by Soolo
Reply #309 on:
June 13, 2017, 22:45:57 »
Dgonix
Карма: +0/-1
www.4pda.ru
Вот это красотень. Благодарю. Буду пробовать.
Reply #310 on:
June 14, 2017, 13:46:26 »
G121121
Карма: +895/-68
BOSE 1801
Last Edit: June 14, 2017, 13:53:04 by Soolo
Reply #311 on:
June 14, 2017, 17:45:13 »
Black_AVP_Bim
Тестер-Ветеран
Карма: +2090/-84
Quote from: G121121 on June 14, 2017, 13:46:26
BOSE 1801
Зачем использовать картинки с настолько уж кривой цветопередачей? Можно было хотя бы в ФШ подправить.
Шкала у индикаторов на самом деле белая:
Reply #312 on:
June 14, 2017, 20:01:06 »
G121121
Карма: +895/-68
насколько я понял школа при работе подсвечивается изнутри-вообще фото с инета-могу обесцветить
(могу ссылки скинуть на цветные индикаторы)
мне самому не нравиться цвет, но приличных исходников почти нет совсем
подсказывайте буду стараться
Last Edit: June 14, 2017, 20:16:11 by G121121
Reply #313 on:
June 14, 2017, 20:15:36 »
Black_AVP_Bim
Тестер-Ветеран
Карма: +2090/-84
Разве можно верить снимкам с инета? Сняты чем попало, никто оцветопередаче не заботится и дополнительно не обрабатывает.
Даже когда индикатор посвечен лампочками накаливания, такого цвета быть не может.
Индикатор сам интересный, а картинка просто ужасная всё в рыжем цвете: и что должно быть белым, и то, что должно быть чёрным. Такую шкалу вообще проще с нуля нарисовать, уйдёт на это 10..15 минут.
Reply #314 on:
June 14, 2017, 20:18:16 »
G121121
Карма: +895/-68
да я не фотошопщик
зрение никудышное и монитора нет с теликом работаю-а на нём цветопередача ващщщще никакошная
Pages:
20
21
22
23
54
Visualizations
