Questions (archive)
Problem with online radio
Topic: Problem with online radio (Read 6293 times)
April 05, 2016, 19:56:25 »
tango3d
Hello everyone,
I spent a long time trying to listen my favourite online radio station on aimp but had no success, I always receive the same message "buffering ..." and then nothing.
The radio page is
http://fmrockandpop.com/
if anyone can help I would appreciate.
Last Edit: April 06, 2016, 16:11:47 by Soolo
Re: Problem with online radio
April 05, 2016, 21:27:25 »
Карма: +477/-74
What is URL you using?
I try
http://up.tzone.qaotic.net/a02/rocknpop_radio1_high-20057/manifest.f4m
But get http access error: error: HTTP/1.1 403 Access denied.
Because i can't JS
http://statics.fluvio.tv/integration/js/pdk.js
correct using in my brain
Read more...
// TODO excluir en futuro
if ( config.asset == "rocknpop_radio1_high-20057"){
var innerHTML = '<object type="application/x-shockwave-flash" name="StrobeMediaPlayback" data="
https://command.fluvio.tv/resources/players/strobemediaplayback.swf
" width="300" height="100" id="StrobeMediaPlayback" style="visibility: visible;">\
<param name="allowFullScreen" value="true">\
<param name="allowScriptAccess" value="always">\
<param name="wmode" value="direct">\
<param name="flashvars" value="autoPlay=true&src=http://up.tzone.qaotic.net/a02/rocknpop_radio1_high-20057/manifest.f4m"></object>';
configuration.htmlElement.innerHTML = innerHTML;
return;
var query = 'asset=' + config.asset;
query += '&type=' + config.assetType;
query += '&autoplay=' + config.autoplay;
query += '&pdk=' + res.ver;
if (config.dynamicIndex){
query += '&dynamicIndex=' + config.dynamicIndex;
if (typeof config.playerMode != 'undefined')
query += '&playerMode=' + config.playerMode;
configuration.iframeURL = res.urls.embed + "?" + query;
configuration.htmlElement.innerHTML = '<iframe src="' + configuration.iframeURL + '" style="height:' + config.height + ';width:' + config.width + ';" frameborder="0" allowfullscreen></iframe>';
configuration.iframe = configuration.htmlElement.getElementsByTagName("iframe")[0];
configuration.iframe.onload = function(){
postMessage({ event: "onConnection", playerId: configuration.id, configuration: config});
When parsing open URL
rtmp://server4.stweb.tv:1935/rockpop - Server error: Failed to play ; stream not found.
[0000000003504c00] avcodec access error: Failed to open rtmp://server4.stweb.tv:1935/rockpop: Operation not permitted
[00000000040eaba0] core input error: open of `rtmp://server4.stweb.tv:1935/rockpop' failed
rtmp://rp.stweb.tv:1935/rockpop/live - Unknown connect error (unsupported authentication method?)
[rtmp @ 00000000045f3160] Server error: Connection failed: Application folder ([install-location]/applications/rockpop) is missing.
[0000000003505740] avcodec access error: Failed to open rtmp://rp.stweb.tv:1935/rockpop/live: Unknown error
[00000000040ebfe0] core input error: open of `rtmp://rp.stweb.tv:1935/rockpop/live' failed
Only rtmp://server4.stweb.tv:1935/rockpop/live
Work in VLC - AIMP not supported RTMP
April 06, 2016, 16:07:39 »
tango3d
Wooowww! Thank you very much Долматов Алексей!
I have no memories of having received aid like this in other forums on other issues
Its sad that aimp not support RTMP, but the good thing is that I can listen my radio on vlc now!
Maybe in the next aimp update I can use it again!
Thanks again for the explanation, for the effort and for your time!
Questions (archive)
