Questions (archive)
Library and Ratings gone after update.
Topic: Library and Ratings gone after update. (Read 4119 times)
February 20, 2016, 11:47:56 »
DGS
Hello,
I've just updated my AIMP3 v3.55.1355 to the latest AIMP v4.00, build 1695.
However when installing I noticed I dont have option to UPDATE current installation to new version.
I install to new folder instead, But now cant restore database from AIMP3.
When I restore backups, and open old version v3.55.1355, everything is still there, But I cant seem to import it to latest version V4.
I tried reinstalling, but the option "UPDATE" install does not appear when i select v.3.55.1355 directory.
When i try reinstall to AIMP v4. Directory "Update" option does appear.
I also try to install v4 as portable and move backup profile folder to v4 install, but library does not load (its different format i think)
Do i need AIMP3 3.60 to use update feature? I was using 3.55.
Also in history.txt i notice this : Fixed: Music Library - import data base from AIMP3 - files from network locations cannot be imported.
Can I force this, or how else fix this issue.
Thanks, love AIMP
Last Edit: February 22, 2016, 08:59:29 by Soolo
Re: Library and Ratings gone after update.
February 20, 2016, 14:00:49 »
Карма: +3230/-79
You must update your version to 3.60, then install new v4.00
February 21, 2016, 14:17:11 »
DGS
That fixed it, thanks!
Questions (archive)
