Questions (archive)
Automatically show path in dialog to the folder of tracks when save playlist?
Topic: Automatically show path in dialog to the folder of tracks when save playlist? (Read 6370 times)
November 30, 2015, 15:28:11 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
When I add tracks from a folder to a playlist and I want to save the playlist, how can I make Aimp to automatically already have the path to that folder added to this dialog:
http://i.imgur.com/Zdz28pK.png
Or, what is the easiest way to add this path to that dialog?
Re: Automatically show path in dialog to the folder of tracks when save playlist?
December 01, 2015, 09:39:53 »
Карма: +3214/-78
AIMP does not have this functionality.
What reason to export playlists from player to external directory?
December 01, 2015, 21:27:35 »
Biff
Карма: +4/-0
Well, I have stored all of my music in separate folders (one album per folder), and when I add the files of an album to Aimp, each album to a single playlist and I want to store the playlist in the folder of the album I each time have to copy the path to the clipboard and enter it into the dialog window of Aimp to save it to that folder.
Or, is there an easier way to do that?
December 01, 2015, 21:30:14 »
Карма: +1406/-190
Why did you save the playlist to the folder?
December 01, 2015, 22:30:26 »
Biff
Карма: +4/-0
When I search for the music I want to play I look search for it in the folders. Where should I save the playlists else, is there a better place?
December 02, 2015, 08:41:56 »
Карма: +1406/-190
AIMP automatically saves playlists
December 02, 2015, 11:42:38 »
Biff
Карма: +4/-0
Yes, I know, Artem told me. But, sorry, what is the connection?
And there are many playlists Aimp automatically has saved not working anymore, because the music folders have been moved, renamed. And furthermore, I want only special playlists being saved, e.g. the ones containing the tracks I like and not the ones containing tracks I never want to hear again. So, after I add tracks to a playlist, I listen to the music and decide, I will not listen to it anymore, the playlist is stored, though. Etc-
Questions (archive)
