Total Members Voted: 116
Still shows 1.2.0 for me, too ... HOWEVER, you fixed my issue with that screenshot.Adding Code: [Select]-f best[ext=mp4]/best to the argument line fixed my file not found problem, so thank you!
Is this normal? It always shows 1.2.0 everytime I update the plugin.By pressing the "Update" button, it says "youtube-dl is up-to-date (2019.06.08)"
If you don't have it, then you did not do a deep cleaning, as I wrote. And you can not say that they did everything exactly, because these arguments are spelled out by default with the proper and clean installation of the plugin.
Msvcr100.dll is not found..
Tried everything from above - nothing worked.
https://www.aimp.ru/forum/index.php?topic=50071.msg386494#msg386494
Youtoube Plugin no longer works - Last test this July 18th at 15:30. Is it possible to fix this problem? thank you in advance. Georges
