Total Members Voted: 123
0 Members and 17 Guests are viewing this topic.
What link?
Plugin is stop working at all (((
It doesn't work with any YouTube link now.
File: https://www.youtube.com/watch?v=N0w11k18I1kCode: -1 (FFFFFFFF)Message: File was not found.
Getting this error:...
It works (proof on screenshot). Try to update plugin again (Maybe you wait not so long enough? just tap Update and wait 1-3min) or reinstall plugin/aimp with deep clean.
youtube-dl is up-to-date (2019.06.08)Press any key to continue . . .
Updating to version 2019.06.08 ...Waiting for file handle to be closed ...Press any key to continue . . . Updated youtube-dl to version 2019.06.08.
Man, i don't know what problem you have with that plugin.Try to reinstall AIMP and plugin with DEEP CLEAN (clean in registry, appdata folders and e.t.c.)I have portable version AIMP from PortableApps (last version) and plugin from https://github.com/jaryn-kubik/AIMPYouTube/releases (this github of this plugin) and push Update any time in plugin settings if plugin not worked.
File: https://www.youtube.com/watch?v=N0w11k18I1kCode: -1 (FFFFFFFF)Message: Unknown Error-------------------------HTTP/1.1 403 ForbiddenLast-Modified: Wed, 02 May 2007 10:26:10 GMTContent-Type: text/plainContent-Length: 0Connection: closeX-Restrict-Formats-Hint: NoneX-Content-Type-Options: nosniffDate: Sun, 09 Jun 2019 20:32:10 GMTServer: gvs 1.0
...I've also searched my computer for any instances of "aimp_youtube" and "youtube-dl", nothing was found....
Try to reinstall plugin to latest version with deep clean. First of all uninstall plugin in Options-Plugins. Further go to Options->bottom left of the screen Profile folders->Delete folder AIMPYouTube->in file AIMP.ini find the block [YouTube] and delete him-save&close file. Then install last version plugin and it will work.P.S.: I hope this process will be easier in the future, but for now it's the only way.
I'd said about DEEP CLEAN from my early post.https://www.aimp.ru/forum/index.php?topic=50071.msg376802#msg376802I hope all be right and plugin will work
-f best[ext=mp4]/best
Still shows 1.2.0 for me, too ... HOWEVER, you fixed my issue with that screenshot.Adding Code: [Select]-f best[ext=mp4]/best to the argument line fixed my file not found problem, so thank you!
