Total Members Voted: 124
I had some problems when playing youtube links. Some times it took too much time to start playing the file and AIMP skipped to the next link. I had to increasse time out on AIMP to avoid this on Player-> Connection-> Timeout to 10000 msec.
It just does the wait for the 5000 msec and then skips over ever video in the playlist once it's resolved that it can't connect.Edit: And I have tried lengthening the 5000 msec till timeout to 30000 and it still didn't work, so I don't think that's the issue.
Полагаю, установка такая же, как в 3.60. Скопировал папку из архива в папку с плагинами. Ну и раз ошибка такая же, то какие могу быть сомнения.У кого есть возможность, проверьте на XP, подтвердите.
AdrianEddy, can you make it compatible with Win XP?
hmm, it should be compatible, could you try installing this https://www.microsoft.com/en-us/download/details.aspx?id=48145 and see if that worked?
I have the same problem when I paste youtube link the program has error in below(attachment)AIMP vers. 4.13 build 1893youtube plugin vers. 0.9
how do I exactly add youtube stream to playlist? I can't find any new context menu items...
