Total Members Voted: 123
I have this doesn't happen, everything is fine. I tried on versions v4.11.1841 and v.4.12.1860 Beta.What version of AIMP are you using?
I use version v4.11.1841 under Windows 10 64-bit.
AIMP crashes each time I try to add e.g. this https://www.youtube.com/playlist?list=PLg-tE9EpLV1hBCS1i5XJJuXdhtFqIkjhr or this https://www.youtube.com/playlist?list=PLg-tE9EpLV1idN2WT_JOO7je1RvgUcw8A link to playlist.
To AdrianEddy.Each time you apply the settings added new copies of commands in the list:
Hello there, YouTube used to work perfectly for me... but now can't play any links anymore... neither the palylist neither new ones.. maybe some YT privacy update? Coud you update the plugin aswell? PLEASE!!!!
It is possible to implement the feature to add videos with timestamp (argument &t=xxx in URL) and playback starting from that time only?
The plugin doesn't use the mechanism of autolocalization and applied it completely by myself.
New version:- Bug fixes- New languages (thanks prydespar and Sztewe!)
~Plugin() { if (!m_finalized) Finalize(); m_instance = nullptr; }HRESULT WINAPI Plugin::Finalize() { Timer::StopAll(); AimpMenu::Deinit(); AimpHTTP::Deinit(); Config::Deinit(); ... Gdiplus::GdiplusShutdown(m_gdiplusToken); <<<<<< I think that error is here m_finalized = true; return S_OK;}
I have checked your code and looks like that plugin trying to release the resources that not be initialized because of IAIMPPlugin.Initialize was not called.Code: [Select] Gdiplus::GdiplusShutdown(m_gdiplusToken); <<<<<< I think that error is here
Try those:
Now memory corruption doesn't exist. But there is a memory leak:
Try with this version
Now, if you start the playback then it will be:If you do not start playback, it will be this:
You're right, should be fixed now:
...но вот опять вечером включил комп захожу на youtube а саб опят ьне звучит там...
У меня не играл саб при просмотре youtube установил плагин этот и как я был рад саб в youtube и вк заработал
